It is currently Thu Aug 14, 2025 11:32 pm
PostPosted: Mon Aug 10, 2015 1:38 pm
Here is the latest Luthier Tips du Jour video - The topic is how to apply the shellac based finish known as Royal Lac. This video as well as all my other videos are available via my website, http://www.obrienguitars.com/videos , LMI's website or on youtube.
Enjoy!
These users thanked the author Robbie O'Brien for the post (total 2): pdolan (Mon Aug 10, 2015 9:39 pm) • dzsmith (Mon Aug 10, 2015 6:04 pm)
PostPosted: Mon Aug 10, 2015 7:09 pm
First name: Wayne
Last Name: Brown
City: Huntersville
Zip/Postal Code: 28078
Thanks Robbie!
I may have to give this a try.
PostPosted: Mon Aug 10, 2015 9:35 pm
Wayne Brown wrote:
Thanks Robbie!
you are welcome. it is very easy to work with.
PostPosted: Mon Aug 10, 2015 10:18 pm
City: Lawrence
Zip/Postal Code: 66047
Thanks Robbie.
I'm guessing that if you don't use seal-lac you'll have problems.
PostPosted: Mon Aug 10, 2015 10:25 pm
Not necessarily. I have tested it with and without and have seen no issues
PostPosted: Tue Aug 11, 2015 10:38 am
First name: Jake
State: CO
Zip/Postal Code: 80129
Thanks for the info. Are there any particular woods where your experience would tell you seal-lac is a good idea? Or probably not needed?
Great video, by the way. As a beginner I find it very helpful to see you doing things. There are many things you could explain to an experienced woodworker in a few sentences, but to a beginner it just doesn't click until I see it.
PostPosted: Wed Aug 12, 2015 10:35 am
I contacted Vijay, the manufacturer, to get his take on this and to offer an in depth answer to your question. Here is his response.
Royal-Lac can be used without Seal-Lac on any bare wood as you did with your sample boards. As a matter of fact that is what is done for the guitar top. Although some put a thin coat of shellac as a sealer.
Most finishes are many a times applied after the wood has been dyed or sealed with a pore filler. As would be for the back, sides and neck of a guitar. In this case it is always a good idea to use Seal-Lac or even dewaxed shellac as a sealer and a barrier coat. Two major reasons:
1) Since Seal-Lac or shellac is a thermoplastic polymer, its adhesive qualities are the best. Moreover when Royal-Lac is applied on top of it, it reactivates the shellac and melds with it to form a single layer. In this way we get excellent bonding as well as durability after cure.
2) The Seal-Lac or shellac also acts as a barrier if a amine based epoxy or glue (most are amine based) or pore filler is used. Any residual amine on the wood surface will reduce the acidity of Royal-Lac that may lead to failure in future.
So the bottom line is: Always apply a thin coat of Seal-Lac or shellac, level sand it and apply Royal-Lac. You will get a finish that will last you a long time.
One more area I would want to touch; It is not a good practice to apply a coat of Royal-Lac and then apply some sort of dye and top it again with Royal-Lac. Always, dye the wood first, apply layers of Seal-Lac or shellac and then start Royal-Lac application.
Finishing is a tricky business. Most finishes fail due to application or process errors. Creating the proper environment for the molecules to move and react with each other is paramount to a finish's success.
Regards,
Vijay
These users thanked the author Robbie O'Brien for the post: ScooberJake (Wed Aug 12, 2015 10:49 am)
